TCustom3dSeries.AddXYZ help incorrect
David
Post by David » Wed May 28, 2008 7:30 am
I am trying to find out how to add a point to a TColorSeries and set the color. There is an AddXYZ in the help for TCustom3DSeries that is incorrect.
It says
The AddXYZ method adds a new point to the Surface Series.
You can also use the Surface OnGetYValue event to supply Y values for a given pair of X,Z values.
Specific colors can be assigned to each Surface polygon by using the AColor parameter.
There is no AColor parameter as far as I can tell, and the help is referring to a surface polygon.
the way that we added the colors are
for i:=0 to 5 do
  for j:=0 to 5 do
    idx:=series1.addXYZ(i,0,j);
    series1.ValueColor[idx]:=clRed;
Is there a way to add a color in just on line. Since a colorgrid is basically useful for displaying a picture, I would like something like
ColorGridSeries.AddXYZ(x,y,someColor)
Post by Narcís » Wed May 28, 2008 10:15 am
Hi David,
You need to populate such series as described on this thread.
You can specify the color in the add mehtod like this:
  for x:=0 to 10 do
    for  z:=0 to 5 do
      Series1.AddXYZ(x,random,z,'',clRed);
That's what the help file means.
David
Post by David » Wed May 28, 2008 2:00 pm
Hi Narcis,
Thanks for the help. If you guys could update the help file to be more accurate, that would be great.
