TeeChart 8 and IntraWeb 9
Claus Nielsen
Post by Claus Nielsen » Thu Apr 03, 2008 10:01 am
I have problems getting the TCharts working with IntraWeb 9 in Delphi 2007. In the old Delphi 7 version of my program everything was running smoothly with the Unit IWCompTeeChart in the uses clause. This unit is not recognized in the Delphi 2007 IDE, and I guess I have to reinstall it somehow. - Can I use the files in the old TeeChartPro7_Intraweb7_Delphi directory? if yes, how?
Post by Yeray » Fri Apr 04, 2008 8:11 am
Hi Claus,
I've prepared, and sent to your registered mail, the sources and the compiled files that work fine here for TeeChart v8, IntraWeb v 9.0 and Delphi 2007.
To use the compiled files, I recommend you the following file distribution:
Copy the design-time bpl (DCLIW90TeeChartPro8_2007.bpl) to delphi's bin folder.
Copy all .dcp and .dcu to delphi's lib folder.
Copy the runtime bpl (IW90TeeChartPro8_2007.bpl) to your windows' system32 folder.
CS
Post by CS » Wed Feb 11, 2009 11:04 am
Please send those files to me too. I also want to use TeeChart V8 in a IntraWeb V9 project using Delphi 2007.
Thanks alot,
CS
Post by Narcís » Wed Feb 11, 2009 11:50 am
Hi CS,
Sure, I just sent you the files.
CS
Post by CS » Wed Feb 11, 2009 12:33 pm
Works fine, thanks again, Narcís.
CS
