TeeChart V7 on 64 bit Windows XP
joschi
Post by joschi » Wed Mar 26, 2008 5:04 pm
I'm trying to install TeeChart V7.11 on Windows XP 64 bit Edition.
After the Installation there is an error shown "TeeChart files to AUTO install can not be found".
I have not seen this problem on Windows XP 32 bit and I did not see any 64 bit version of TeeChart V7.
Is TeeChart V7 usable on 64 bit systems?
Can I Install the files manually?
Thanks!
Post by Yeray » Thu Mar 27, 2008 11:16 am
Hi joschi,
By the while, we have no constancy of any problem with TeeChart v7 in 64 bits. It should work fine.
Please, try using provided tool TeeInstall.exe
If doesn't solve your problem, could you tell us the exact environment you are trying to use to test it here? (delphi version)
joschi
Post by joschi » Thu Mar 27, 2008 12:03 pm
I solfed the problem by manually add the bpl files.
I use Delphi 2007 (Version 11.0.2709.7128)
Thanks for your help!
