Whenever I change the default color of an axis title, at runtime occurs an exception:
Error reading [Component]->[Axis]->Title.Color property Color does not exist.
the only way to make it run, is lefting the default values.
It seems a bug in the "TChartAxisTitle" class
I'm working with teeChart for VCL/CLX pro version.
TeeChart pro 8.02 TChartAxisTitle Bug
Hi okra,
This works fine for me here using TeeChart Pro v8.02 VCL in Delphi and C++ Builder projects. Can you please confirm this is the same version you are using and, if the problem persists, send us a simple example project we can run "as-is" to reproduce the problem here?
You can either post your files at news://www.steema.net/steema.public.attacments newsgroup or at our upload page.
Todo correcto
Gracias Narcís por tan rápida respuesta.
Busqué en mi sistema posibles librerias antiguas y encontré librerías de versiones anteriores que no se desinstalaron automáticamente.
Probé de nuevo y todo está funcionando a la perfección.
Asunto cerrado.
Muchas gracias.
okra.
Asunto cerrado.
Muchas gracias.
okra.
