Title editor only?
moelski
Title editor only?
Post by moelski » Tue Jan 08, 2008 7:54 am
Hi support,
is it possible to use only that part of the charteditor which is responsible for editing the title? Our customers want to change the title of the chart without using the whole charteditor.
It should like a window with the following items ...
Is this possible ?
Post by Narcís » Tue Jan 08, 2008 8:31 am
Hi Dominik,
Yes, this is possible using a TChartEditor and setting HideTabs to all tabs except for cetTitles. You can do this either at run-time or design-time. A run-time example can be found at All Features\Welcome!\Components\Chart Editor\Chart Editor dialog.
moelski
Post by moelski » Tue Jan 08, 2008 8:54 am
Hi Narcis,
Ok that works, but there is one problem left ...
The Tabs at the top of the form are not really nice in this case ... Can I hide them, too?
Post by Narcís » Tue Jan 08, 2008 8:57 am
Hi Dominik,
I'm afraid not. You could try setting the editor in tree mode or customizing your chart editor.
moelski
Post by moelski » Tue Jan 08, 2008 9:10 am
Hi Narcis,
well tree mode is not better then the normal mode.
Would it be a solution to build my own Dialog? I found something like this within the V8 demo :
InsertTeeObjectForm(PageControl1,Chart1.Title).RefreshControls(Chart1.Title);
But the example won´t work in the V8 demo. Could you please give me an example which creates the toolbox within a form?
Post by Narcís » Tue Jan 08, 2008 10:07 am
Hi Dominik,
Have you tried adding necessary units in the uses section?
Uses TeeCustomShapeEditor;
moelski
Post by moelski » Tue Jan 08, 2008 10:32 am
Hi Narcis,
is it only possible to use Function InsertTeeObjectForm with a pagecontrol?
Function InsertTeeObjectForm(APageControl:TPageControl; AShape:TTeeCustomShape):TFormTeeShape;
Is there no way to use a form instead ?
moelski
Post by moelski » Tue Jan 08, 2008 10:54 am
Hi Narcis,
ok I tried to add a form with a pagecontrol.
Then I use:
InsertTeeObjectForm(Form1.PageControl1,Chart1.Title).RefreshControls(Chart1.Title);
to create the Editor.
This works, but only Format and Border are filled. Text, Gradient, Shadow, Picture are complete empty.
Look at the demo -> Miscellaneous -> Titles and Footers -> Generic Format
You will see that Text, Gradient, Shadow, Picture are white / empty, too.
moelski
Post by moelski » Wed Jan 09, 2008 1:37 pm
Hi !
No idea what causes this problem ?
Post by Pep » Mon Jan 14, 2008 12:16 pm
Hi Dominik,
using the following code should be the correct way :
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,  Dialogs, StdCtrls, Buttons, TeeEdit, TeEngine, Series, ExtCtrls,
  TeeProcs, Chart, ComCtrls, TeeCustomShapeEditor, TeeEdiGrad, TeeEdiFont, TeCanvas, TeePenDlg, TeeBackImage, TeeShadowEditor;
type
  TForm1 = class(TForm)
    PageControl1: TPageControl;
    procedure PageControl1Change(Sender: TObject);
  private
    { Private declarations }
    TheTitle           : TChartTitle;
    ITeeObject    : TFormTeeShape;
    FFontEditor     : TTeeFontEditor;
    FGradientEditor : TTeeGradientEditor;
    FImageEditor    : TBackImageEditor;
    FShadowEditor   : TTeeShadowEditor;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
begin   InsertTeeObjectForm(PageControl1,Chart1.Title).RefreshControls(Chart1.Title);
procedure TForm1.PageControl1Change(Sender: TObject);
  with TPageControl(Sender) do
  if ActivePage.ControlCount=0 then
     if ActivePage=PageControl1.Pages[2] then
       FFontEditor:=InsertTeeFontEditor(Pagecontrol1.Pages[2]);
       if Assigned(Chart1.Title) then
          FFontEditor.RefreshControls(Chart1.Title.Font);
     end
     if ActivePage=Pagecontrol1.Pages[3] then
         FGradientEditor:=TTeeGradientEditor.CreateCustom(nil,Chart1.Title.Gradient);
         AddFormTo(FGradientEditor,PageControl1.Pages[3]);
     end
     if ActivePage=PageControl1.Pages[4] then
       FShadowEditor:=InsertTeeShadowEditor(PageControl1.Pages[4]);
          FShadowEditor.RefreshControls(Chart1.title.Shadow);
     end
     if ActivePage=Pagecontrol1.Pages[5] then
       FImageEditor:=InsertImageEditor(PageControl1.Pages[5]);
       if Assigned(Chart1.title) then
          FImageEditor.RefreshControls(Chart1.Title.Picture);
end.
moelski
Post by moelski » Fri Jan 18, 2008 11:04 am
Hi Pep,
Works great so far.
But I miss the tab "Style" and "Position". Is it possible to add this two tabs into the pagecontrol?
Then I would have a perfect solution to change the title. :)
xxxxxx
Post by xxxxxx » Sun Jan 20, 2008 6:52 pm
Hi, Pep and Dominik!
Isn't it simpler? :wink:
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
  ExtCtrls, ComCtrls, TeeEdiTitl, TeePenDlg, Chart, Series, TeEngine, TeeProcs;
type
    Chart1: TChart;
    Series1: TAreaSeries;
    Panel1: TPanel;
  private
    TheTitle           : TFormTeeTitle;
  public
  Form1: TForm1;
implementation
{$R *.DFM}
  TheTitle := TFormTeeTitle.CreateTitle(Self,Chart1,Chart1.Title);
  AddFormTo(TheTitle,Panel1);
  TheTitle.Align:=AlClient;
end.
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
moelski
Post by moelski » Mon Jan 21, 2008 9:05 am
Hi Alex,
your code is great and works perfect. Thx alot !!!
I have added some line to create the form and the panel from code. Now it looks like this:
var Form      : TForm;
    Panel     : TPanel;
  Form := TForm.Create(self);
  Form.Caption      := 'Set Title';
  Form.BorderStyle  := bsSizeToolWin;
  Form.Height       := 300;
  Form.Width        := 400;
  Panel := TPanel.Create(Form);
  Panel.Parent  := Form;
  Panel.Align   := AlClient;
  AddFormTo(TheTitle, Panel);
  TheTitle.Align := AlClient;
  Form.ShowModal;
  Form.Free;
Annotation: You need to include TeeEdiTitl, TeePenDlg.
Thx again ! :D
xxxxxx
Post by xxxxxx » Mon Jan 21, 2008 7:46 pm
9349911 wrote: your code is great and works perfect.
It isn't mine, it's Steema's!
UTSL!!!:wink:
Regards, Alexander
