bug in Function TQRChart.GetChart:TQRDBChart;
jls
Post by jls » Fri Jan 04, 2008 10:19 am
In unit QrTee;
If you try to load a TQRChart runtime from stream it fails.
procedure TQRChart.ReadState(Reader: TReader);
var tmpChart : TQRDBChart;
tmpChart:=Chart;
The reason is here:
  if ControlCount=0 then
     CreateChart;
  result:=TQRDBChart(Controls[0]);
Change it to
     CreateChart;
  if ControlCount>0 then result:=TQRDBChart(Controls[0])
    else result:=nil;
Jørgen Storlie
Bert Kreisel
Post by Bert Kreisel » Thu Jan 10, 2008 10:21 am
Thank you very much! I can work with TeeChart 8.02 in QuickReport 4.07 only with your patch. The programmer from Steema have to include this code in the next release (as it was OK in 7.12)!
Behalves Bert Kreisel
Post by Yeray » Mon Feb 04, 2008 11:04 am
Hi Jørgen and Bert,
I'm glad to announce that this issue has been already fixed so this will be solved with the next maintenance release.
