Simple Pie
matthias
Simple Pie
Post by matthias » Fri Nov 23, 2007 10:37 am
I need to draw a very simple pie chart with
- different color fills,
- separated by lines in one color different to that of the pie pieces,
- no shadow,
- with no line around the pie.
I used
Series.ColorEachPoint:=true;
Series.Pen.Visible:=false;
Series.Shadow.Visible:=false;
Series.Dark3D:=false;
Series.PiePen.Visible:=false;
Series.Color:=Color;
The resulting pie shows still a line around that seems to be a "trace" of a shadow.
What can I do?
Thanks for all help!
Matthias
Post by Yeray » Fri Nov 23, 2007 11:07 am
Hi Matthias,
I cannot see any shadow line using applying your code to a new pie series.
However, you could try without 3d view or setting the pie circled. Maybe it looks better for you.
Chart1.View3D := false;
Series.Circled := true;
Also note that the separation line you mention is the same as the border. So, if you want a separation line in one color, it will be the same in the border.
Series.PiePen.Visible:=true;
Series.PiePen.Color := clBtnShadow;
Series.PiePen.Width := 2;
And could you please tell us what TeeChart version are you using?
Thank you in advance.
matthias
Post by matthias » Fri Nov 23, 2007 1:24 pm
I found out that the AntialiasTool is the problem:
The strange visual effect appears after adding
AntialiasTool:=TAntiAliasTool.Create(Self);
AntialiasTool.AntiAlias:=true;
Chart1.Tools.Add(AntialiasTool);
I use version TeeChart Pro v. 8.01
Matthias.
Post by Narcís » Fri Nov 23, 2007 3:05 pm
Hi matthias,
Yes, I see the problem now. It only happens with AntiAlias tool. This seems a bug to me and I've added it (TV52012605) to our defect list to be fixed for future releases.
