More advanced Schemes
Posted: Mon Apr 19, 2004 2:07 pm
by 9336918
Tis me again
The schemes change colours and backgrounds beautifully BUT not the title fonts. How do you edit the schemes especially the titles please?
Thanking you
Morton
Posted: Mon Apr 19, 2004 8:32 pm
by Marjan
Hi, Morton.
All you have to do is define any additional chart properties you want to change in your theme Apply method. Here is part of the TWebTheme.Apply implementation:
procedure TWebTheme.Apply;
Const clDarkSilver=$C4C4C4;
WebFont='Lucida Console';
var t : Integer;
inherited;
Chart.BevelInner:=bvNone;
Chart.BevelOuter:=bvNone;
Chart.Border.Visible:=True;
Chart.BorderRound:=0;
Chart.Border.Width:=1;
Chart.Border.Color:=clBlack;
Chart.Gradient.Visible:=False;
If you want to change chart Title properties, you derive new theme from your current theme and add the following lines in the Apply method (just an example):
procedure TYourTheme.Apply;
inherited;
with Chart.Title do
Font.Name:='Arial';
Font.Size:=10;
Font.Color:=clNavy;
Font.Style:=[fsBold];
Also, check the theme examples in Teechart demo. They should give you some additional tips on how to build custom chart themes.
Posted: Wed Apr 21, 2004 9:03 am
by 9336918
Many thanks BUT... How can I apply this to an EXISTING theme.
1. Being each theme now has a changed title font each say excel has a large one, blues a small one ands so on...
2. A global font for all the titles that the themes don't override - so you set the font opnce and any theme you choose keeps the same title font.
3. The final thought is how does one do all this create a brand new theme... based on say the Excel one and call it Excel2 or from scratch...
Thanking you again
Morton
Posted: Fri Apr 23, 2004 4:49 am
by Marjan
Hi, Morton.
If you have TeeChart source code, you can add relevant parts to theme Apply method. Or alternatively (much better) derive new theme from your existing theme, inherit it's Apply method and add additional properies you want to set. The code is really simple:
TMyTheme = class( TExcelTheme)
public
procedure Apply; override;
class function Description:String; override;
procedure TMyTHeme.Apply;
inherited;
with Chart.Title do
Font.Name:='Arial';
Font.Size:=10;
Font.Color:=clNavy;
function TMyTheme.Description: string;
result:='My custom theme';
initialization
RegisterChartThemes([ TMyTheme ]);
Now the TMyTheme will inherit all TExcelTheme properties + add your own. Of course, you can also derive directly from TChartTheme and fully customize everything in the Apply method implementation.
I hope this will help you in deriving and using new custom theme.
