Problem installing TeeChart 8
johnnix
Post by johnnix » Sat Aug 04, 2007 12:54 pm
1. I have Turbo Delphi Pro and I am trying to install TeeChart 8 Pro (OS XP). After running the installer I get an error message "TeeChart files to AUTO install cannot be found". Should I uninstall the 4.04 version prior running the installer?
2. If I try to install the components manualy I get several errors regarding tee100.bpl.
johnnix
Post by johnnix » Sat Aug 04, 2007 4:48 pm
TeeInstall also gives me an error "TeeChart files cannot be found under current folder structure. Current folder: xxxxx" where xxxxx is my current folder and it is correct
johnnix
Post by johnnix » Sun Aug 05, 2007 8:57 am
I did the following steps:
1. Uninstalled Turbo Delphi
2. Installed Turbo Delphi
3. Applied HotFix Rollup 2
4. Downloaded TeeChart Standard 7.09 from GodeGear web site
5. Run the installer and everything worked fine (I run a test project and works ok. Also during the installation procedure I got a warning about an old version found)
6. Downloaded TeeChart Pro 7 (latest version) from your site
7. Run the installer and at the end of the procedure I get the same error "TeeChart files to AUTO install cannot be found".
I run out of ideas so any help would be most welcomed
P.S. The installation procedure worked ok in my old PC running Windows 2000. My new PC has Windows XP (Service Pack 2) Media Center Edition
johnnix
Post by johnnix » Mon Aug 06, 2007 7:46 am
Ok, I finally managed to manually install version 8 but I was wondering if anyone else had the same problem with the installer.
Post by Yeray » Mon Aug 06, 2007 7:57 am
Hi johnnix,
Could you please tell us the installer's full name you are exactly using? TeeChart8.01Delphi2006.exe, TeeChart8.0Delphi2005.exe or which?
johnnix
Post by johnnix » Mon Aug 06, 2007 8:11 am
Post by Yeray » Tue Aug 07, 2007 7:37 am
Hi johnnix,
Thanks for your prompt reply. We are happy to see that you've achieved to install the palette and we want you to know that we'll try to fix this minor bug on future releases.
