TeeUseMouseWheel and OnAllowScroll problem
xxxxxx
Post by xxxxxx » Fri Jul 27, 2007 12:44 pm
The problem is that scrolling with MouseWheell doesn't fire OnAllowScroll event thus preventing me from control of moving all series outside ChartRect.
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Pep » Fri Jul 27, 2007 4:04 pm
Hi Alexander,
yes, since we add this checking on our sources (which is on our wish list) it will have to be done manually.
You could use the OnAfterDraw event to do it, using similar code to the following one :
procedure TForm1.Chart1AllowScroll(Sender: TChartAxis; var AMin,
  AMax: Double; var AllowScroll: Boolean);
 // your code here...
var axisleftmin,axisleftmax : double;
    scroll : boolean;
  axisleftmin := Chart1.axes.left.minimum;
  axisleftmax := Chart1.axes.left.maximum;
  scroll := true;
if TeeUseMouseWheel=true then
  Chart1AllowScroll(chart1.Axes.Left,axisleftmin,axisleftmax,scroll);
xxxxxx
Post by xxxxxx » Fri Jul 27, 2007 5:07 pm
Seems you meant in a such way?
  if scroll then
    chart1.Axes.Left.SetMinMax(axisleftmin,axisleftmax)
Unfortunately, at the point, marked with questions, previous minimum and maximum of an axis are already lost and refusing scroll is not possible:cry:
Have a good weekend!
Regards, Alexander
Post by Pep » Mon Jul 30, 2007 4:26 pm
Hi Alexander,
hmmm... how about ?
  private
    min, max : double;
  if (Chart1.AllowPanning = pmVertical) or (Chart1.AllowPanning = pmBoth) then
    if (Amin<=min) or (Amax >= Max) then
        AllowScroll := false;
    axisleftmin2,axisleftmax2 : double;
    scroll : boolean;
if assigned(Series1) then
  if min = -1 then
   min := Chart1.Axes.Left.Minimum;
  if max = -1 then
    max := Chart1.Axes.Left.Maximum;
    if scroll then
      min := axisleftmin;
      max := axisleftmax;
    end
    else begin
     Chart1.Axes.Left.SetMinMax(min,max);
xxxxxx
Post by xxxxxx » Mon Jul 30, 2007 6:43 pm
Thank you, Pep for this suggestion!
By this moment I undertook more radical workaround - completely intercepted default TeeChart scroll behavior in OnMouseWheel event.
Regards, Alexander
xxxxxx
Post by xxxxxx » Wed Aug 01, 2007 1:08 pm
By the way, scrolling with mouse seems ignores AllowPanning value :(
Post by Narcís » Wed Aug 01, 2007 2:03 pm
Hi Alexander,
What about using TabStop property as suggested on this thread?
xxxxxx
Post by xxxxxx » Wed Aug 01, 2007 2:12 pm
Hi, Narchs!
It's not a problem for me to enable scroll, the issue is how to handle it in a uniform way with trapping OnAllowScroll event and in accordance with AllowPanning value.
For better understanding let me bring up just an example - for some reasons I prevent a user from dragging series with Right Mouse by AllowPanning=pmHorizontal, however it (politely to say - he or she) is still able to shift series in vertical using MouseWheel.
For my projects I have already found a workaround, but in general I suggest this behavior must be changed.
Regards, Alexander
Post by Narcís » Wed Aug 01, 2007 2:45 pm
Hi Alexander,
Ok, as Pep said, this is already listed on our wish-list to be implemented for next releases.
xxxxxx
Post by xxxxxx » Wed Aug 01, 2007 3:02 pm
narcis wrote: Ok, as Pep said, this is already listed on our wish-list to be implemented for next releases.
That's true, but because we discussed with him OnAllowScroll event I just added to the discussion AllowPanning issue. If it's also included into your wish list I'm almost (until next release:) satisfied.
Post by Pep » Tue Aug 07, 2007 11:59 am
Hi Alexander,
Thanks for the advise. Yes, it's on our wish list too.
