How to use ZoomRect with CustomAxis?
moelski
Post by moelski » Tue Jul 17, 2007 8:06 am
Hi !
I have some customaxis in my chart which need to bee zoomed.
In the OnZoom Event I use this code:
var Achse   : TChartAxis;
    i       : Byte;
 if Chart1.Zoom.Direction in [tzdBoth, tzdVertical] then
  for i := 0 to Chart1.SeriesCount - 1 do begin
    Achse := Chart1.Series[i].GetVertAxis;
    if Achse.Visible then
      Achse.SetMinMax(Achse.CalcPosPoint(Chart1.Zoom.Y1),Achse.CalcPosPoint(Chart1.Zoom.Y0));
If I try to zoom in / Zoom out with the ZoomRect function the chart alsways zoom out.
I use the sample from your helpfile:
Zoom in example:
Chart1.ZoomRect( Rect( 5,5,Chart1.Width-5,Chart1.Height-5 ) );
Zoom out example:
Chart1.ZoomRect( Rect( -5,-5,Chart1.Width+5,Chart1.Height+5 ) );
What must I do in order to zoom in and zoom out correctly the axis using ZoomRect ?
Post by Pep » Tue Jul 17, 2007 9:21 am
Hi Dominik,
have you tried using similar code to the following ?
    var tmp: TChartAxis;
      Series1.FillSampleValues(20);
      tmp := (Chart1.CustomAxes.Add as TChartAxis);
      tmp.OtherSide:=true;
      tmp.Horizontal:=false;
      tmp.PositionPercent:=20;
      Series1.CustomVertAxis:=tmp;
    With Series1.GetVertAxis
      SetMinMax(CalcPosPoint(Chart1.IZoom.Y1),CalcPosPoint(Chart1.IZoom.Y0));
    Series1.GetVertAxis.Automatic:=true;
moelski
Post by moelski » Tue Jul 17, 2007 9:56 am
Hi Pep !
This won´t work for me.
I´ve uploaded a small demo appilcation to your server:
Received ZoomRect Test.zip Content Type application/x-zip-compressed Length 13796
Zoomin and Zoomout always does the same.
moelski
Post by moelski » Fri Jul 20, 2007 9:27 am
Hi Pep,
did you checked my demo application ?
xxxxxx
Post by xxxxxx » Sun Jul 22, 2007 11:42 am
On request of Dominik I post here a piece of my code using ZoomRect
//From OnMouseWheel hanlder
if WheelDelta>0 then
        ZoomPercentage:=ZoomInRate*WheelDelta
        ZoomPercentage:=ZoomOutRate*WheelDelta;
      with ChartRect do
        InflateRect(ChartRect,Round((Right-Left)*ZoomPercentage/100),Round((Bottom-Top)*ZoomPercentage/100));
      ZoomRect(ChartRect);
//From UndoZoomHandler
 with ParentChart, CustomAxes do
 for iX:=0 to Count-1 do
 with Items[iX] do
   Automatic:=True;
moelski
Post by moelski » Mon Jul 23, 2007 6:31 am
Hi xxxxxx,
could you please add some information for the variables?
ZoomInRate, ZoomOutRate What value do you use for this?
ChartRect How if it defined and how to set the values?
moelski
Post by moelski » Mon Jul 23, 2007 7:02 am
Hi !
I tried this:
procedure TForm1.Chart1MouseWheel(Sender: TObject; Shift: TShiftState;
  WheelDelta: Integer; MousePos: TPoint; var Handled: Boolean);
  ZoomInRate, ZoomOutRate     : double;
  ChartRect : TRect;
if ([ssShift,ssCtrl] <= Shift) then begin
  ZoomInRate  := 2;
  ZoomOutRate := 2;
  ChartRect := Rect( 0,0,Chart1.Width,Chart1.Height);
  with ChartRect do
  Chart1.ZoomRect(ChartRect);
This won´t work for me. Could you please post an example of your whole Chart1MouseWheel procedure?
