Bollinger Color
quickweb
Bollinger Color
Post by quickweb » Thu Jul 12, 2007 3:22 pm
I don't know what I am doing wrong with settings for bollinger function properties because the LowBand color is not updated. The color is update in the same time with highband and with color of this.
I create a function with default properties, and after that assign new properties:
// set Bollinger function properties
TLineSeries* fSeries = Object->series;
TBollingerFunction* f = (TBollingerFunction*)fSeries->FunctionType;
fSeries->SeriesColor = clGreen;
fSeries->Pen->Style = psSolid;
fSeries->Pen->Width = 1;
fSeries->YValues->ValueSource = "Close";
f->Period = 14;
fSeries->FunctionType->Period = f->Period;
f->Deviation = 2;
f->Exponential = true;
f->LowBandPen->Color = clAqua;
f->LowBandPen->Style = psSolid;
fSeries->CheckDataSource();
Thanks for your help,
Cristina
Post by Pep » Fri Jul 13, 2007 9:03 am
H Cristina,
using the following code works fine here, could you please check if it works for you ? (appologies for Delphi code) :
    MySeries: TCandleSeries;
    MyFunctionSeries: TLineSeries;
  Chart1.View3D := false;
  MySeries:=TCandleSeries.Create(Self);
  MySeries.ParentChart := Chart1;
  // you must create second series for Bollinger
  MyFunctionSeries := TLineSeries.Create(Chart1);
  MyFunctionSeries.ParentChart := Chart1;
  MyFunctionSeries.SetFunction(TBollingerFunction.Create(Chart1));
  // connect original series to MyFunctionSeries
  // now MyFunctionSeries will get it's (calculated) data from MySeries
  MyFunctionSeries.DataSource := MySeries;
  With (MyFunctionSeries.FunctionType as TBollingerFunction) do
    Deviation:=2;
    Period:=14;
    Exponential:=true;
    LowBandPen.Style := psDash;
    LowBandPen.Color := clnone;
  // populate date and refresh Bollinger function/series
  MySeries.FillSampleValues(100);
  MyFunctionSeries.CheckDataSource;
    LowBandPen.Style := psSolid;
    LowBandPen.Width := 2;
    LowBandPen.Color := clAqua;
quickweb
Post by quickweb » Fri Jul 13, 2007 11:24 am
I think, my code is the same (in C++).
More than that when I read the lowbandpen color I read the right color.
But the series are drawn both with fSeries color (the parent series).
Thank you for your quick answer,
cristina
Post by Pep » Mon Jul 16, 2007 6:30 am
Hi cristina,
please try to change the order of the line in the code, this could be the cause. Try to post the lines where the lowbandpen color is changed after the CheckDataSource line.
quickweb
Post by quickweb » Mon Jul 16, 2007 7:44 am
Thank you verry much.
It works.
Cristina
