Hi Marjan Slatinek:
I know TDrawLineTool can draw single line, but I don't know how to draw complexer line(Bezier curves, arcs, ...) ,and I wish end-user can select and drag complex curves as if TDrawLineTool control single line.
TDrawLineTool:
0: Lines.Last.Style:=dlLine;
1: Lines.Last.Style:=dlHorizParallel;
2: Lines.Last.Style:=dlVertParallel;
I Wish TDrawLineTool have
3: Lines.Last.Style:=dlBezier;
4: Lines.Last.Style:=dlarcs;
5: Lines.Last.Style:=dlWaves;
I have reviewed TDrawLineTool's code in the TeeChart Pro 7, but not found.
I don't know how to do it
jilonger.xusen
How to draw complexer line(Bezier curves, arcs, ...) ?
- Newbie
Hi.
As I said in my post this feature is not supported at TDrawLineTool level. This tool (currently) supports only straight from-to line drawing. We'll add the feature you described to our wish list for next major TeeChart release.
In the meantine if you want to draw non-straight-line curves, you can manually draw them by using one of the TChart.Canvas primitives in one of the TChart events (for example OnAfterDraw event).
Marjan Slatinek,
- Newbie
procedure TDrawLineTool.DrawLine(const StartPos, EndPos: TPoint;
AStyle: TDrawLineStyle);
i:integer;
with ParentChart.Canvas do
if ParentChart.View3D then
case AStyle of
dlLine:
MoveTo3D(StartPos.X, StartPos.Y, 0);
LineTo3D(EndPos.X, EndPos.Y, 0);
dlHorizParallel:
HorizLine3D(StartPos.X, EndPos.X, StartPos.Y, 0);
HorizLine3D(StartPos.X, EndPos.X, EndPos.Y, 0);
VertLine3D(StartPos.X, StartPos.Y, EndPos.Y, 0);
VertLine3D(EndPos.X, StartPos.Y, EndPos.Y, 0);
end
end
{HTS画线开发的扩展线形入口}
case AStyle of
dlLine: Line(StartPos.X, StartPos.Y, EndPos.X, EndPos.Y);
dlHorizParallel:
DoHorizLine(StartPos.X, EndPos.X, StartPos.Y);
DoHorizLine(StartPos.X, EndPos.X, EndPos.Y);
dlVertParallel:
DoVertLine(StartPos.X, StartPos.Y, EndPos.Y);
DoVertLine(EndPos.X, StartPos.Y, EndPos.Y);
end
dl?????:
for i:=0 to abs((EndPos.X-StartPos.X)) div 10 do
if (EndPos.X-StartPos.X)<0 then
DoVertLine(StartPos.X+i*(-10),ParentChart.ChartRect.Top, ParentChart.ChartRect.Bottom)
else DoVertLine(StartPos.X+i*10,ParentChart.ChartRect.Top, ParentChart.ChartRect.Bottom);
If I do it so , I can succeed?
i:integer;
case AStyle of
dlLine:
dlHorizParallel:
end
end
{HTS画线开发的扩展线形入口}
case AStyle of
dlHorizParallel:
dlVertParallel:
end
dl?????:
Hi.
Yes, it might work, but you'll have to replace the straight line drawing with property Bezier and arc drawing code (not by using line segments, but rather by using true arc and bezier methods). But be aware that in addition you'll also have to modify other methods, especially the tool OnChartMove event implementation. This mainly because if you want to draw bezier or arc you need more than two points to define specific curve.
Marjan Slatinek,
- Newbie
