ZoomIn ZoomOut with MouseWheel ?
moelski
Post by moelski » Fri Jul 06, 2007 9:06 am
Hi !
Is it possible to Zoom in and Zoom out with the mousewheel ?
How can I realize this?
Post by Narcís » Fri Jul 06, 2007 9:26 am
Hi Dominik,
Yes, this is possible using this code:
  Chart1.TabStop:=true;
  TeeUseMouseWheel:=true;
moelski
Post by moelski » Fri Jul 06, 2007 9:48 am
Hi !
Well I added
  TeeUseMouseWheel    := true;
  Chart1.TabStop      := true;
in FormCreate
but nothing happend. Are ther some other properties which have to be set (or not)?
Something is interesting:
procedure TForm1.Chart1MouseWheel(Sender: TObject; Shift: TShiftState;
  WheelDelta: Integer; MousePos: TPoint; var Handled: Boolean);
  beep;
This procedure is never fired up when use the wheel from my mouse.
Any suggestions ?
Post by Narcís » Fri Jul 06, 2007 9:53 am
Hi Dominik,
Code below works fine for me here using latest v8 release available. Which TeeChart version are you using? Can you please test if this works fine at your end?
  Chart1.Title.Text.Add('Hi');
moelski
Post by moelski » Fri Jul 06, 2007 10:00 am
I did a test with a really small sample application. The mousewheel works.
But it only scrolls the y-axis.
Is it possible to scroll the x-Axis, too?
And how can I use the mouse wheel to zoom in / out (what is the interesting part for me)?
Post by Narcís » Fri Jul 06, 2007 10:07 am
Hi Dominik,
This may work provided you have a mouse that supports horizontal wheel scrolling.
Sorry for overlooking the original message. In that case you can do something like in this C++ Builder example:
void __fastcall TForm1::FormMouseWheel(TObject *Sender, TShiftState Shift,
	  int WheelDelta, TPoint &MousePos, bool &Handled) {
	Chart1->Zoom->Animated = false;
	if(WheelDelta > 0)
	  Chart1->ZoomPercent(110);
	if(WheelDelta < 0)
	  Chart1->ZoomPercent(90);
moelski
Post by moelski » Fri Jul 06, 2007 10:13 am
Ok thx !
But what the hell can cause Chart1MouseWheel to be never fired up?
In my simple demo it works. My bigger demo don´t bring this event.
var i: Integer;
This is the start from FormCreate. So in general it should work ?! :?
Post by Narcís » Fri Jul 06, 2007 10:20 am
Hi Dominik,
Is there any other mouse event on your project that may be overriding the OnMouseWheel event? If so you could try commenting in those events and check if it makes a difference.
moelski
Post by moelski » Fri Jul 06, 2007 10:27 am
Hi !
No there is only a ChartListBox2MouseDown. But this shouldn´t be a problem.
I tried to put another Chart to the mainform. Set
  Chart2.TabStop      := true;
and added some sample data to the series 1. In my simple demo this works fine. In my bigger dimo this won´t work, too.
So could it be possible that there is something worng in the mainform? There are no other mousewheel events.
Strange thing ....
moelski
Post by moelski » Fri Jul 06, 2007 10:31 am
This works:
procedure TForm1.FormMouseWheel(Sender: TObject; Shift: TShiftState;
xxxxxx
Post by xxxxxx » Fri Jul 06, 2007 1:29 pm
From my point of view:
1. First, make sure you Chart in your big demo is the active control, otherwise it won’t fire OnMouseWheel event.
2. It’s useful to add in OnChartClick event handler something like
procedure TForm1.Chart1Click(Sender: TObject);
  ActiveControl:=Chart1;
or
  Chart1.SetFocus;
to allow user to set focus to chart without tabbing, just clicking it.
3. And finally in OnMouseWheel event handler write something like that
  Percentage : double;
  if ([ssShift,ssCtrl] <= Shift) then
    with Chart1 do begin
      if WheelDelta>0 then
        Percentage:=100+0.045*WheelDelta
        Percentage:=100+0.05*WheelDelta;
      ZoomPercent(Percentage);
      Handled:=True;
    end
  if ([ssAlt,ssCtrl] <= Shift) then
    with Chart1.BottomAxis  do begin
      Scroll(WheelDelta*(Maximum-Minimum)/1000,False);
      Handled:=True;
this enables user to use Ctrl+Shift together with mouse wheel for zooming in and out,
Ctrl+Alt together with mouse wheel for horizontal scrolling and still allow him to use plain MouseWheel for vertical scrolling.
4. Last bun not least, thank you for a good tip how to organize more clever Unzoom under control of user, I just work on this issue, because standard TeeChart Unzoom to the original 100% is not always what user expects.
Alexander
moelski
Post by moelski » Fri Jul 06, 2007 3:18 pm
I only have to say once:
THANK YOU VERY MUCH !!! :D
That´s absolutely great ... fantastic :shock: :D
moelski
Post by moelski » Thu Jul 12, 2007 6:01 am
Hi !
There are still 2 small problems:
1) custom Y axis
I use only custom Y axis and I zoom these axis with this code:
var Achse   : TChartAxis;
    i       : Byte;
  if Chart1.Zoom.Direction in [tzdBoth, tzdVertical] then
  for i := 0 to Chart1.SeriesCount - 1 do begin
    Achse := Chart1.Series[i].GetVertAxis;
    if Achse.Visible then
      Achse.SetMinMax(Achse.CalcPosPoint(Chart1.Zoom.Y1),Achse.CalcPosPoint(Chart1.Zoom.Y0));
And this is my code for the MouseWheel:
      if (WheelDelta > 0) then Chart1.ZoomPercent(110)
                          else Chart1.ZoomPercent(90);
      Handled:=True;
If you try this and use the scrolling wheel for zooming (with pressed Shift, CTRL) the Y axis are zoomed dramatically. The axis are approximated zoomed with the factor 1000-2000. You can´t see any series any more.
If I don´t use the Chart1Zoom Event, then the Y axis won´t be zoomed. Only the x axis - what is ok.
2) Scrolling chart with the mouse wheel
I use this code:
  if ([ssAlt] <= Shift) then
      Handled:=True;
  Chart1.SetFocus;
Works great in both directions. You can scroll vertical by pressing the Alt key and it works. If you want to scroll horizontal by releasing the Alt key you have to click into the chart first. If you don´t click you won´t be able to scroll the chart in horizontal direction.
How can I change this so that no additional click is necessary?
Post by Pep » Thu Jul 12, 2007 10:03 am
have you tried changing the :
Chart1.SetFocus;
by
xxxxxx
Post by xxxxxx » Thu Jul 12, 2007 10:46 pm
9349911 wrote:If you try this and use the scrolling wheel for zooming (with pressed Shift, CTRL) the Y axis are zoomed dramatically.
Event fires each time you turn a wheel - 10% for each Wheel movement is too much!
9349911 wrote: If I don´t use the Chart1Zoom Event, then the Y axis won´t be zoomed.
It seems we work in parallel direction. My work is on progress, I can only mention I turned from ZoomPercent to ZoomRect and now it works with custom axis as well.
9349911 wrote: You can scroll vertical by pressing the Alt key and it works. If you want to scroll horizontal by releasing the Alt key you have to click into the chart first. If you don´t click you won´t be able to scroll the chart in horizontal direction.
I didn't catch the point. Your code and comment regarding Alt-key operation seems controversial. Anyhow, firing Wheel event is beyond TeeChart and it seems you have enable TChart to catch it yourself, i.g. providing handler for OnExit events of all other contols, or may be catch corresponding Window message.
