Very slow Smoothing function
moelski
Post by moelski » Fri May 04, 2007 11:49 am
Hi !
I did some tests with the smoothing function because we need it for curve smoothing.
What I tested was the following:
- new application
- add TeeChart component
- add 2 FastLine Series to the Chart
- Series -> Data Source
> set Series1 to Random (1000 values)
> set Series2 to Function -> Smoothing (Series: Series1)
> click Apply
If you click the apply button as the last step, TeeChart takes a really long time for calculation. The problem gets bigger if you increase the random values to 10000. The application will hang for a long time.
Is this a bug? I can´t imagine why it takes such a long time to calculate a smooth (interpolated) line.
Any hints?
Post by Pep » Mon May 07, 2007 4:47 pm
Hi Greetz,
it's not a bug, the code used to calculate the spline takes huge CPU time with more than 500 points.
I've added a note on out wish list ( try to improve the speed ) to be considered for further releases.
moelski
Post by moelski » Tue May 08, 2007 5:05 am
Hi Pep,
thx for that info.
When do you think is this topic fixed?
Greetz Dominik
btw: May name isn´t Greetz :wink: Greetz = Greetings
Post by Pep » Tue May 08, 2007 11:09 am
Hi Dominik,
I'm sorry, I annot tell for sure when will be check it in order to be improved. If you are "source code" customer you can take a look the TeeSpline unit and try to find a way to speed it.
>>> btw: May name isn´t Greetz Greetz = Greetings
Ups !.. sorry :wink:
moelski
Post by moelski » Tue May 08, 2007 12:47 pm
Hi Pep,
Ok I will take a look. We have the source code.
But I think we will mplement our own calculation.
Anyway ... It would be great if you could fix this problem in the future.
Greetz
