export to PDF, seting resolution
nitin
Post by nitin » Fri Apr 27, 2007 5:58 am
hello
like in topic, is there possibility to set resolution of pdf ? We have problem that when we have large number of points on chart after export to pdf file we are not able to read it (deatails)
thanks in advance
Post by Yeray » Fri Apr 27, 2007 7:44 am
Hi guzial,
You should try different values for width and height of the following function (uses TeePDFCanvas).
TeeSaveToPDFFile(Chart1, 'c:\temp\mychart.pdf', width, height);
