mulitcolor serie
nitin
mulitcolor serie
Post by nitin » Thu Apr 05, 2007 6:48 am
in design mode i set color of serie as white.
during programm i create dynamically values of serie from DB.
      case FBLDsql1.FieldByNameAsInt64('VALUE') of
        0 : Chart1.Series[0].AddXY(FBLDsql1.FieldByNameAsDateTime('DATE'), FBLDsql1.FieldByNameAsInt64('FUEL'), '', clGreen);
        1 : Chart1.Series[0].AddXY(FBLDsql1.FieldByNameAsDateTime('DATE'), FBLDsql1.FieldByNameAsInt64('FUEL'), '', clYellow);
i wanted to have lineseries with two colors, some pixels in one color some in other.
How to do it corect because now i have serie in one color - white
please help me ASAP
thanks in advance
Post by Yeray » Thu Apr 05, 2007 11:18 am
Hello guzial,
Ensure that you have set the following properties to true:
YourLineSeries.ColorEachLine:=true;
YourLineSeries.ColorEachPoint:=true;
If this doesn't help, could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page
nitin
Post by nitin » Thu Apr 05, 2007 11:34 am
i don't have such a property like
ColorEachLine
i use teeChart 7.08
Post by Narcís » Thu Apr 05, 2007 11:44 am
Hi guzial,
Have you tried ColorEachPoint property instead? If this doesn't help please let us know which series style are you using.
nitin
Post by nitin » Thu Apr 05, 2007 11:48 am
yes i tried and it doesnt work
i use fastLineSeries
Post by Narcís » Thu Apr 05, 2007 1:46 pm
Hi guzial,
Are you setting this before populating your series? If the problem persists please send us a simple example project we can run "as-is" to reproduce the problem here.
nitin
Post by nitin » Fri Apr 06, 2007 8:34 am
i send to newsgroup and im waiting impatiently for solution ;)
Post by Yeray » Tue Apr 10, 2007 8:08 am
Hi guzial,
We're sorry but you should use TLineSeries to achieve ColorEachPoint to work properly.
nitin
Post by nitin » Tue Apr 10, 2007 8:16 am
i cann't use lineseries due to a large amount of points
Post by Yeray » Tue Apr 10, 2007 9:08 am
Hi guzial,
you can take a look at this article to optimize your LineSeries.
nitin
Post by nitin » Tue Apr 10, 2007 9:16 am
i cann't use tlineseries because i make at runtime chart with few lines with points between 500000 - 1000000 and more each line
Post by Yeray » Tue Apr 10, 2007 10:23 am
Hi guzial,
Following the steps in the article above I've made an example with 6 series and 1000000 points in each one and it takes about 8 seconds to draw the chart in my machine. The code I use is:
unit Unit1;
interface
uses
  Dialogs, TeEngine, Series, ExtCtrls, TeeProcs, Chart, StdCtrls;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TLineSeries;
    Series2: TLineSeries;
    Series3: TLineSeries;
    Series4: TLineSeries;
    Series5: TLineSeries;
    Series6: TLineSeries;
    Button1: TButton;
    procedure Button1Click(Sender: TObject);
    procedure AddValues(i: Integer);
  private
    { Private declarations }
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
var MaxPoints, ScrollPoints : Double;
// Prepare chart for maximum speed:
  with Chart1 do
    ClipPoints := False;
    Title.Visible := False;
    Legend.Visible := False;
    LeftAxis.Axis.Width:=1;
    BottomAxis.Axis.Width:=1;
    BottomAxis.RoundFirstLabel := False;
    View3D := False;
  // Number of points we'll be displaying
  MaxPoints:=10000;
  // Number of points deleted when scrolling chart
  ScrollPoints := 5000;
  // Prepare series.
  // Disable AutoRepaint and X Order
  Chart1.AutoRepaint := False;
  // Set Ordering to none, to increment speed when adding points
  Series1.XValues.Order := loNone;
  Series2.XValues.Order := loNone;
  Series3.XValues.Order := loNone;
  Series4.XValues.Order := loNone;
  Series5.XValues.Order := loNone;
  Series6.XValues.Order := loNone;
  // Initialize axis scales
  // we're assuming left axis values are within [0,1000]
//  Chart1.LeftAxis.SetMinMax(0,10000);
//  Chart1.BottomAxis.SetMinMax(1,MaxPoints);
  // Speed tips:
  // When using only a single thread, disable locking:
  Chart1.Canvas.ReferenceCanvas.Pen.OwnerCriticalSection := nil;
  Series1.LinePen.OwnerCriticalSection := nil;
  Series2.LinePen.OwnerCriticalSection := nil;
  Series3.LinePen.OwnerCriticalSection := nil;
  Series4.LinePen.OwnerCriticalSection := nil;
  Series5.LinePen.OwnerCriticalSection := nil;
  Series6.LinePen.OwnerCriticalSection := nil;
procedure TForm1.AddValues(i : Integer);
Var X,Y : Array of Double;   // TChartValues
    t   : Integer;
    Num : Integer;
  { 1M points }
  Num:= 1000000;
  { allocate our custom arrays }
  SetLength(X,Num);
  SetLength(Y,Num);
  { fill data in our custom arrays }
  X[0]:=0;
  Y[0]:=Random(10000);
  for t:=1 to Num-1 do
    X[t]:=t;
    Y[t]:=Y[t-1]+Random(101)-50;
  { set our X array }
  With Chart1[i].XValues do
    Value:=TChartValues(X);  { <-- the array }
    Count:=Num;               { <-- number of points }
    Modified:=True;           { <-- recalculate min and max }
  { set our Y array }
  With Chart1[i].YValues do
    Value:=TChartValues(Y);
    Count:=Num;
    Modified:=True;
Var i : Integer;
  for i := 0 to 5 do
    AddValues(i);
  { Show data }
  Chart1.AutoRepaint := True;
  Series1.Repaint;
end.
nitin
Post by nitin » Tue Apr 10, 2007 11:47 am
ok, but you prepare your data in memory and everything depend on your computer; in my situation i have to preapre data from database so it takes few seconds than i use method addxy and before each point is divided and than multiply by some value and everthing makes that it takes so long time
