Dates before 1900
Hans Hasenack
Dates before 1900
Post by Hans Hasenack » Mon Mar 05, 2007 2:04 pm
I need to show dates before 1-1-1900, (back to 1-1-1850!)
Is there a specific reason why Function TChartAxis.LabelValue
says
if Value>=0 then...
It makes it impossible to display dates before 1-1-1900
(I had to patch it in teechart sourcecode)
Post by Narcís » Mon Mar 05, 2007 2:39 pm
Hi Hans,
Yes, this is because TDateTime's implementation in the VCL as you can see in Delphi's help files.
However, you could use something like this unit.
Hans Hasenack
Easy patch
Post by Hans Hasenack » Mon Mar 05, 2007 2:44 pm
All I did was replace the if aDate>0 then... by
if True then...
And it works like a charm. When using negative date values now,
labels are omitted until 1900 and then displayed... ???
Post by Narcís » Mon Mar 05, 2007 3:34 pm
Hi Hans,
Ok, thanks for the information.
In that case you can add the labels using Add method's override Add(YValue,Label,Color) or AddXY(XValue,Label,Color). Another option would be customizing the labels in the OnGetAxisLabel event.
Hans Hasenack
I know..
Post by Hans Hasenack » Mon Mar 05, 2007 3:42 pm
But I'd rather be able to display dates before 1900 as default behavior than having to write an event handler for this in every spot where I use TCharts.
(Over 300!) :shock:
Hans Hasenack
I uploaded word document with example
Post by Hans Hasenack » Mon Mar 05, 2007 4:09 pm
I just applied the
"If True" Patch
Check out Pre_1900_Dates.doc
which I just uploaded.
