TeeChartSeries.AssignFormat
Can you change following 4 lines
Self.FHorizAxis := FHorizAxis;
Self.FCustomHorizAxis:= FCustomHorizAxis; // 6.01
Self.FVertAxis := FVertAxis;
Self.FCustomVertAxis := FCustomVertAxis; // 6.01
Into
Self.HorizAxis := HorizAxis;
Self.CustomHorizAxis:= CustomHorizAxis; // 6.01
Self.VertAxis := VertAxis;
Self.CustomVertAxis := CustomVertAxis; // 6.01
In order to make sure the Assign method is called? This is required to ensure (reloaded) series will be linked onto the correct axis.
TChartSeries.Assignformat uses unsafe Assignment
- Newbie
Thanks for your suggestion Hans.
I've added your request to our wish-list to be reviewed and considered for inclusion in next releases.
- Newbie
Wish List
Actually, it is a bug present from teeChart 5 already.
When loading chart settings, the chart becomes the 'owner' of the Tpersistent derived objects from another chart, causing AV's later on when the other chart is freed!
I guess I'll have to keep my patch for now...
Hi Hans,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
- Newbie
I'll Have to find some time to do this
I am currently under some time pressure.
This problem, however appeared during Teechart5 days when assigning a TChart (and copying series) to a TQRChart. My problem demo project got lost somewhere in time...
I'll let you known asap when I have some mini project to demonstrate the problem.
