CAn not create DLL with TAnnotationTool
BE
Post by BE » Fri Mar 02, 2007 6:41 pm
HI,
I have a program I was trying to convert to DLL. The program includes TChart and TAnnotationTool. I had the program converted and using a driver program to load the DLL, but when I tried to run it, it crashes every time. When I remove the TAnnotationTool, the program runs OK. I'm a bit surprised, because I have ATChart in the DLL ahd it had no problem finding and loading it. What am I missing in this TAnnotation?
-Bill
Post by Narcís » Mon Mar 05, 2007 8:55 am
Hi Bill,
Are you including TAnnotationTool unit in the uses section?
BE
Post by BE » Mon Mar 05, 2007 3:29 pm
I should be clear that I'm using BCB 6. The .exe version works find. However, the DLL version will not start. The TChart is included in my project and it had no problem being loaded.
What I have is "#include TeeTool.hpp". What else do I need to be included in the project?
-Bill
Post by Pep » Mon Mar 12, 2007 9:37 am
Hi Bill,
which error are you getting ?
BE
Post by BE » Fri Mar 16, 2007 2:07 am
When I run my driver program, I get the windows msg
The application failed to initialize properly (0xc000005). Apperanetly window can not find a DLL or a package. When I remove TAnnatationTool from my application, the error goes a way.
-Bill
Post by Pep » Mon Mar 19, 2007 11:50 am
Hi Bill,
we're going to need an example with which we can reproduce as is the problem here. Would you be so kind to send me it directly to pep@steema.com ?
