How to align two charts
efa
Post by efa » Thu Mar 01, 2007 2:56 pm
Hello!
On my form I have 2 TCharts. I need to display the two charts directly beneath each other so that the two left axes are perfectly aligned and the ChartWidth of the two charts is exactely the same.
Is this possible?
Erik
Post by Narcís » Thu Mar 01, 2007 3:09 pm
Hi Erik,
Yes, this is possible. You can try doing something as told here.
efa
Post by efa » Thu Mar 01, 2007 3:25 pm
Hi!
I did try that but unfortunately it will not work because the legends of the two charts has different sizes. How can I compensate for this?
Erik
Post by Yeray » Fri Mar 02, 2007 11:18 am
In the following example, we made two series in two different charts, we set different legend widthes and aligned them.
  Series1.FillSampleValues(100);
  Series2.FillSampleValues(200);
  //Creating diferent size titles for each legend
  Chart1.Legend.Title.Text.Clear;
  Chart1.Legend.Title.Text.Add('Chart1 Title xxxxxxxxxxxx');
  Chart2.Legend.Title.Text.Clear;
  Chart2.Legend.Title.Text.Add('Chart2 Title');
  LeftAlignCharts([Chart1,Chart2],100,600);
  Chart1.Draw;
  Chart2.Draw;
  RightAlignCharts
//this is the method to resize the charts that Narcis suggested to you before
procedure TForm1.LeftAlignCharts(Const Charts: Array of TCustomChart; aLeft: Integer; aWidth: Integer);
var i: Integer;
  for i := Low(Charts) to High(Charts) do
  // Left align charts
  With Charts[i] do
    Left := aLeft;
    Width := aWidth;
    MarginLeft := 0;
    Axes.Left.TitleSize := 15;
    Axes.Left.LabelsSize := 30;
    Axes.Left.LabelsAlign := alDefault;
//This is to resize the chart which has a smaller legend.width
procedure TForm1.RightAlignCharts;
     if Chart1.Legend.Width > Chart2.Legend.Width then
          Chart1.Legend.HorizMargin:=10;
          Chart2.Legend.HorizMargin := Chart1.Legend.Width - chart2.Legend.Width + Chart1.Legend.HorizMargin;
     end
              Chart2.Legend.HorizMargin:=10;
              Chart1.Legend.HorizMargin := Chart2.Legend.Width - chart1.Legend.Width + Chart2.Legend.HorizMargin;
I hope it helps.
