TeeChart7 Installation Problems
Posted: Wed Mar 17, 2004 7:09 am
by 8443014
Hi have tried to install TeeChart 7, I am using BCB 6 SP 4, and get the following error:
EXCEPTION:
Can't load package C:\PROGRA~1\STEEMA~1\TEECHA~2\BuilderC6\Bin\DclTee7C6.bpl.
The system cannot find the file specified
I tried to install it manually by first uninstalling TeeChart 4 that ships with BCB, then copy all the files in the TeeChart 7 directory to the corresponding directories under CBuilder6 directory. Then I installed all the components in the bin directory.
This installed TeeChart 7 and I could add the component to my form, and add a series, but when I compiled I got empty axis.
Please can you tell me what I need to do.
Thank You
Posted: Wed Mar 17, 2004 12:45 pm
by Pep
Hi Neil,
yes, I think there's a problem using the installer in some BCB versions,
we're working on this, we'll post a new installer on our web site as soon as
possible. In meantime you can add manually all the TeeChart Pro v7 packages
manually from the Menu -> Components --> Install packages list. Also, do not
add the following packages, there're for Standard version of Delphi/BCB :
DclTeeChartProStd7C6
DclTeeChartStd7C6
