Get Y value without using mouse click
nileiqi
Post by nileiqi » Fri Feb 16, 2007 4:53 am
I have two series lines on the chart, one is real time line, the other is predicated line which is ploted shortly after the application startup, the real time line will be plotted each time when a data arriving. One thing I want to do is to plot another line called "residual",in order to calculat the residual, the application needs to know the Y value of predicated line at the time when application is ploting the real-time data point.
The question is how to get the Y value of the chart already plotted ? if I use click event, there is an example in user manual can help me out, but without using such event handler, how can I get a plotted line's Y value ? without using click ? Thanks in advance.
Daniel
Post by Yeray » Fri Feb 16, 2007 8:50 am
Hi nileiqi,
If your real-time line and your predicated line share the same X values then your problem could be solved with some like following:
(Note that we added 3 series and a timer to the form in design time and also note that we calculate residual points by subtraction of RealTime from Predicated).
    PredicatedLine.FillSampleValues(100);
procedure TForm1.Timer1Timer(Sender: TObject);
   index: Integer;
   PredicatedLineValue: double;
   RealTimeLineValue: double;
     index := RealTimeLine.Add(random*1000);
     if index < PredicatedLine.Count then
          PredicatedLineValue := PredicatedLine.YValue[index];
          RealTimeLineValue := RealTimeLine.YValue[index];
          ResidualLine.Add(PredicatedLineValue - RealTimeLineValue);
But if real-time line and predicated line don't share the X values, the the problem will be solved in a more complicated way, but we'll suggest you a solution.
nileiqi
Post by nileiqi » Tue Feb 20, 2007 4:42 am
Yeray,
Thanks for your help. I realize that you assume same index for both predicated and realtime line, that not suits my case. They both share same X values (date time), the difference is that predicated line contains whole year length data, index =1 represents the first data of year, eg 2007-01-01 00:05:00, while for realtime line, index=1 represents first receiving data after the program starts running, if program starts now, index=1 represents the data at 2007-02-20 15:30:00.
My request is when I plot realtime point at current datetime, how do I get the Y value of predicated line at this datetime ? (the X value is date time). Below is how do I plot the predicated line, it may help to understand my question, Thanks in advance.
Daniel
My chart spans 24 hours and shifts left at certain time. the X values is date time axis. I plot predicated line in this way, simply create a big array to carry one-year data, then call following pseudo code:
For i:=1 to predicated_line.count
AddXY(predicated_line.datetime, predicated_line.value )
Then TeeChart looks after predicated line, when I change the time span or shift time range, the predicated line always be plotted properly.
[/b]
Post by Yeray » Tue Feb 20, 2007 9:48 am
Hi nileiqi,
if we undestand your problem it should be solved using locate function, something like following:
     PredicatedLine.XValues.DateTime := True;
   index: Integer;
   i: Integer;
          i := PredicatedLine.XValues.Locate(RealTimeLine.XValue[index]);
          PredicatedLineValue := PredicatedLine.YValue[i];
nileiqi
Post by nileiqi » Wed Feb 21, 2007 12:31 am
Hi, Yeray
I don't fully understand following code
it returns i:=-1, it looks like corresponding point index can not be found, I did call PredicateLine.AddXY() to add all predicated data point into series list, online help file seems not completed for function Locate(..). Thanks in adcance.
Daniel
Post by Yeray » Wed Feb 21, 2007 9:11 am
Hi Daniel,
probably not all your XValues for RealTime have a corresponding XValue in PredicatedLine.
So you'll probably need to compare for each XValue if it has a corresponding XValue in PredicatedLine. But then there are two possibilities:
-Assuming for all XValues, if they have an image, they are exaclty identic; same day, minute and second:
   index: Integer;
   i: Integer;
          for i := 0 to  PredicatedLine.Count-1 do
             if (PredicatedLine.XValue[i] = RealTimeLine.XValue[i]) then break;  // if values are equal for day, minute and second
-Assuming for all XValues, if they have an image, they are in the same day:
   index: Integer;
   i: Integer;
             if (Abs(PredicatedLine.XValue[i] - RealTimeLine.XValue[i]) < 1 ) then break;  // if values are equal in the same day
nileiqi
Post by nileiqi » Thu Mar 01, 2007 5:19 am
Yeray,
Thank you,I got it.
Kind regards
Daniel
