3D Bit Map Chart Walls
CAC
Post by CAC » Tue Dec 26, 2006 8:41 pm
Is it possible to assign a bitmap to a 3D Wall that can then be rotated in 3D space? I have tried assigning an image to a wall, put it appears to be just a transparent window to a bitmap behind the chart canvas.
Post by Pep » Thu Dec 28, 2006 9:17 am
this feature (allow to assign an image for the walls) has been added into the upcoming release v8 which we're working on.
In the existing TeeChart Pro v7 in you only want to add an image to the back wall you can use the TImageTool (you can find one example of use into the Demo Features project).
