Dialogs are cropped when large fonts are used at 1600x1200
Posted: Mon Aug 28, 2006 3:32 am
by 9337233
When large fonts are used and the screen display is set to 1600x1200, many of the Teechart user interface dialogs are cropped. I can send you pictures of the dialogs if you like. Switching to small fonts displays the dialogs just fine.
I am unable to adjust the size of the dialogs because the recompile tool gives the following error: found explicitxxxx in form: ExplicitWidth = 377.
Typically I design at 1600x1200 large fonts and then verify that my app looks ok at lower resolutions and with small fonts.
How can I change the dialogs sizes and use the recompile tool to update the changes.
I have D2006 Pro and Teechart 7.07 installed.
It would be a good idea to verify your user interface dialogs at high screen resolution and large fonts. Displays won't be getting smaller!
Thanks for your help.
Dan Sox
I can send you screen shots if you like.
Posted: Mon Aug 28, 2006 7:11 am
by Marjan
Hi, Dan.
Hmm. One quick and dirty workaround might be to remove ExplicitWidth and ExplicitHeight lines from form dfm files (you can use Notepad.exe for this).
