Changing origin for sidestacked bars
Andrew S
Post by Andrew S » Mon Jul 31, 2006 9:04 pm
I am using TeeChart Pro 7.06. I can't figure out how to change the origin of a chart containing horizontal stacked bars.
Using non-stacked bars it's simply a matter of setting Series.UseYOrigin := true and Series.YOrigin := -100 (for example). But when I introduce a stack, the origin seems to have little to no effect. Any suggestions as to why? I would like to have two stacked horizontal bar series, and have the lower bar's origin somewhere around -95.
-A
stark
Post by stark » Tue Aug 01, 2006 8:29 am
Hello Andrew S,
I tried to reproduce your problem. For me this works fine:
Series2.UseYOrigin := true;
Series2.YOrigin := -100    ;
Series1.UseYOrigin := true  ;
Series1.YOrigin := -100    ;
Series1.FillSampleValues(2);
Series2.FillSampleValues(2);
Maybe I miss understood your question. Let use know if there is any further information helping use to help you.
Alex
Steema Crew
Andrew S
Post by Andrew S » Tue Aug 01, 2006 1:30 pm
A slight modification to your code shows exactly what I'm asking...
  Series2.YOrigin := -100;
  Series2.StackGroup := 1;
  Series2.MultiBar := mbStacked;
  Series1.UseYOrigin := true;
  Series1.YOrigin := -100;
  Series1.Stackgroup := 1;
  Series1.MultiBar := mbStacked;
Notice that, even though the bottomaxis' minimum has been modified, the stack still originates at 0?
-A
Post by Pep » Tue Aug 01, 2006 2:11 pm
Hi Alex,
yes, you're correct, it still not prepared to be used with Stack and negative YOrigin, I've adde this on our defect/wish list to be considered for the next maintenance releases.
Andrew S
Post by Andrew S » Tue Aug 01, 2006 2:18 pm
I notice in the release notes for 7.07 that it mentions improvements to the way stacked bars are drawn. Does this include my issue, or is that going to be a future release?
-A
