hi,
i gues this is a weird quest, I just wonder if there's a way I can add all 6 faces to the chart box. For now, it only supports left, bottom, back and right, but I wish I can add top and front plane too while at normal mode or OpenGL mode.
and also this might be a bug, at OpenGL mode, if you set all axises(left, bottom, top) to be NOT automatic, ex from 0 to 5 and delta to be 1, the data points (ex. bubble 3D) are not correctly plotted at their depth coordinates (z), but if I set axes automatic, then they're fine.
Fang
