Default mark position of stack bar charts
Frank
Post by Frank » Tue May 23, 2006 5:12 am
Hey guys,
I 'm using teechart 7 vcl for my project. I noticed that on stack bar charts I made, if i have multiple series, the marks of previous series are always overlapped and hidden by the bars of next series. Any thoughts on that?
thanks!
Post by Narcís » Tue May 23, 2006 7:31 am
Hi Frank,
You can reposition the marks by doing something like this:
var i: Integer;
  for i:=0 to Chart1.SeriesCount-1 do
    Chart1[i].FillSampleValues();
    Chart1[i].Marks.ArrowLength:=-30;
    Chart1[i].Marks.Arrow.Visible:=false;
Frank
Post by Frank » Tue May 23, 2006 3:54 pm
Thank you for the quick reply, Narcis.
However, i see another issue with stack bar charts. What if i want to display the marks in the middle of bars? Do i have to find out the length of bar first and then specifiy the arrowlength base on that? If that's the case i guess i need to specify different arrowlengths for marks that in the same series, am i right?
Post by Narcís » Wed May 24, 2006 7:52 am
Hi Frank,
Yes, or you can also use custom marks as shown here:
  i: Integer;
  APosition:TSeriesMarkPosition;
  Series1.FillSampleValues();
  Chart1.Draw();
  APosition:=TSeriesMarkPosition.Create;
  try
    for i:=0 to Series1.Count-1 do
      APosition.Custom:=True;
      APosition.LeftTop.X:=Series1.Marks.Positions[i].LeftTop.X;
      APosition.LeftTop.Y:=Series1.Marks.Positions[i].LeftTop.Y-35;
      Series1.Marks.Positions[i]:=APosition;
  finally
      APosition.Free;
Frank
Post by Frank » Thu May 25, 2006 8:33 pm
Hi Narcis,
Is there any easy way that i can tell the lengths of bars of each value point in each series? It seems like i need to find out those to be able to specify the arrowlengths of marks.
Any thoughts?
thanks a bunch.
Post by Pep » Tue May 30, 2006 2:44 pm
Hi Frank,
yes, you can check where a specified point (bar) starts and ends using the code below. This example shows how to position Marks in the middle of each stacked Bar Series :
series1.FillSampleValues(5);
Series2.FillSampleValues(5);
Series3.FillSampleValues(5);
procedure TForm1.PositionChartMarks(BarSeries: TBarSeries);
  i: integer;
  YPos: integer;
  BarTop: integer;
  BarBottom: integer;
  XPos: integer;
  MarkPos: TSeriesMarkPosition;
  MarkPos := TSeriesMarkPosition.Create;
  try
    for i := 0 to BarSeries.Count - 1 do begin
      // just an example, you can do further customization here
      MarkPos.Width := BarSeries.BarWidth;
      MarkPos.Height := 16;
      BarTop := BarSeries.CalcYPos(i); // get y screen pixel coordinate
      BarBottom := BarSeries.CalcYPosValue(BarSeries.PointOrigin(i,false));
      YPos := (BarTop + BarBottom - MarkPos.Height) div 2;
      // Make sure that the value isn't painted below the X Axis
      if YPos > (BarSeries.GetHorizAxis.PosAxis - (MarkPos.Height)) then begin
        YPos := BarSeries.GetHorizAxis.PosAxis - (MarkPos.Height);
      XPos := BarSeries.CalcXPos(i);
      MarkPos.Custom := True;
      MarkPos.LeftTop.X := XPos;
      MarkPos.LeftTop.Y := YPos;
      BarSeries.Marks.Positions[i] := MarkPos;
  finally
    MarkPos.Free;
  BarSeries.Repaint;
procedure TForm1.Series1BeforeDrawValues(Sender: TObject);
  PositionChartMarks(Sender as TBarSeries);
end.
Frank
Post by Frank » Tue May 30, 2006 7:33 pm
Cool, this is exactly what i 'm looking for. Thanks Pep!
