Chart Editor Doesnt Show
Posted: Tue Feb 10, 2004 8:05 pm
by 8442798
Ive just Installed Ver 6.01 For Delphi6. When I right Click on any chart and select Edit Chart The Chart Editor does not show but is obviously in existence as I cannot do anything until I press the ENTER key.(Probably closing the chart editor).
Anyone had this problem?
Posted: Tue Feb 10, 2004 11:16 pm
by Pep
Hi Martha,
strange.. you are the first person with this problem that I know. Are you able to edit other options (dialogs) like "Print-Preview" , "Export Chart" or "Tab Order" using a TButton ?
Posted: Wed Feb 11, 2004 1:32 pm
by 8442798
Yes, All others work fine. I have the same problem with the DBChart and QRQhart.
I have unistalled and reinstalled TChart. Also I have created a new project and aded aTchart all with the same results.
Martha
Posted: Wed Feb 11, 2004 2:04 pm
by 8442798
I have solved this. My screen res was set at 1024 X 768. I changed it to 1920 X 1200 and the chart editor appeared on the left side of the monitor. I moved it to the right and reset screen res to 1024 X 768. I think it was appearing off of the screen.
Martha
