TeeChartpro 7.0x is not compatible with ReportBuilder 10.xx
Delphi2005 gives "compile in different version of Teexxx.xxxx"
How can i install this components without problem.
TeeChartpro 7.0x problem with ReportBuilder 10.x Delphi2005
Hi ttg,
For Report Builder compatibility with TeeChart you should ask Digital Metaphors support (Report Builder manufacturers) as they are the ones who develop the Report Builder wrapper for TeeChart.
However, this kind of errors use to be because the IDE has a version conflict and different packages are referencing different versions of the same package. IIRC, Report Builder 10 added support for TeeChart Pro v7.06 but you'd better check that with Digital Metaphors.
