Tic Labeling Question
leaf
Post by leaf » Wed Feb 15, 2006 2:41 pm
I am trying to develop a work around to the many problems with the TcolorGridSeries plot type. Specifically, because of the slow display update rate when IrregularGrid is set to true, I need to label the axis tics manually when ever they are drawn.
Setting the labels manually using the following code works just fine:
Chart1.Axes.Bottom.Items.add(i,Format('%-.2f',[x]));
However, if I add a label for evey element, a repaint will attempt to draw them all.
Question: Is there a way to add labels only for the large (or major tic marks) Tics that are currently display on the screen? I will need to handle this for zooms and pans as well.
Thank you in advance.
Post by Pep » Mon Feb 20, 2006 10:19 am
why you don't use the OnGetAxisLabel or the OnGetNextAxisLabel events ?
Plase see the Help for details.
