printing annotations using the chartpreviewer has still 2 effects.
1. Printing with smoothing --> position of annotations are ok
2. Printing without smoothing --> annotations are print with a negative offset
I've tested this with the "New feature demo".
Can you please help me.
Best Regards
Dirk Zirwes
Problem with printing annotations
Hi Dirk,
The best solution is to use the temporary metafile + StretchDraw method to print charts with custom objects (text, annotation, etc..).
The Rect parameter in StretchDraw defines the drawing rectangle, in this case printer.canvas drawing rectangle.
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls,
Forms,
Dialogs, StdCtrls, TeEngine, TeeTools, Series, ExtCtrls, TeeProcs,
Chart,
TeeComma;
type
TForm1 = class(TForm)
Chart1: TChart;
Series1: TLineSeries;
ChartTool1: TAnnotationTool;
TeeCommander1: TTeeCommander;
procedure CustomClickEvent(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
Form1: TForm1;
implementation
Uses Printers;
{$R *.dfm}
procedure TForm1.CustomClickEvent(Sender: TObject);
var tmpMeta: TMetafile;
Chart1.BevelOuter := bvNone;
Chart1.Frame.Visible := False;
tmpMeta := Chart1.TeeCreateMetafile(True,Chart1.ClientRect);
try
Printer.Orientation := poLandscape;
Printer.BeginDoc;
try
Printer.Canvas.StretchDraw(Rect(10,10,Printer.PageWidth -
10, Printer.PageHeight - 10),tmpMeta);
finally
Printer.EndDoc;
finally
tmpMeta.Free;
Series1.FillSampleValues(10);
TeeCommander1.ButtonPrint.OnClick := CustomClickEvent;
end.
