How do I manually add points to a TeeChart in QRDesign?
bpetty
Post by bpetty » Wed Feb 01, 2006 10:15 pm
My data is stored in a Blob in a Paradox database so I don't think I could easily use the Data Aware method of drawing curves. How do I access the Chart pointer within QRDesign to be able to add to the series? Or is there a better way?
Thank you in advance for your help.
Post by Pep » Mon Feb 13, 2006 3:55 pm
you can use a regular stream to save/load the chart.
Here is an example how you can save/load Chart to/from a BLOB field (an
example is for ADOTable):
Uses ..., TeeStore;
var tmp: TStream;
    ADOTable1.Append;
    tmp :=
ADOTable1.CreateBlobStream(Table1.FieldByName('BlobFieldName'),bmWrite);
    try
        SaveChartToStream(Chart1,tmp);
    finally
        tmpStream.Free;
Similarly you can load chart from blob field :
var tmp: TStream;
tmp :=
ADOTable1.CreateBlobStream(Table1.FieldByName('BlobFieldName'),bmRead);
try
    LoadChartFromStream(Chart1,tmp);
finally
    tmpStream.Free;
