When is PosAxis updated?
to2
Post by to2 » Fri Jan 27, 2006 4:57 pm
I would like to arrange some icons near a vertical axis. Because I move the axes I have to recalculate the relative positions of the icons to the axis. When I change TChart->MarginLeft and TChartAxis->PositionPercent, TChartAxis->PosAxis is not updated immediately. When is this value updated?
Post by Narcís » Mon Jan 30, 2006 9:49 am
Hi to2,
You may force them being changed by re-drawing the chart using Chart1.Invalidate or Chart1.Refresh methods.
to2
Post by to2 » Mon Jan 30, 2006 4:37 pm
narcis wrote:You may force them being changed by re-drawing the chart using Chart1.Invalidate or Chart1.Refresh methods.
I set all units to pixels. LeftAxis is invisible.
Chart1->MarginLeft  = 35;
Chart1->LeftAxis->PositionPercent = 0;
IMO Chart1->LeftAxis->FPosAxis should be 35 now.
DebugInspector: Chart1->LeftAxis->FPosAxis=0
Chart1->LeftAxis->Visible = true;
Chart1->Refresh();
Next Time I run this code -> DebugInspector: Chart1->LeftAxis->FPosAxis=35
FPosAxis gets its 35 pixels but I don't know when. I can't force it by Invalidate(), Refresh(), Repaint(). What I want to prevent is a Application->ProcessMessages().
Post by Pep » Wed Feb 08, 2006 8:45 am
to do this you should use the OnAfterDraw event, using similar code to the following all custom objects (like texts,..) are moved changing the margins.
procedure TForm1.BitBtn1Click(Sender: TObject);
Chart1.MarginLeft  := 35;
Chart1.LeftAxis.positionPercent := 0;
Chart1.Canvas.TextOut(Chart1.LeftAxis.PosAxis,Chart1.BottomAxis.PosAxis,'hello world');
