Legend size seems incorrect
David Novo
Post by David Novo » Fri Jan 06, 2006 11:01 pm
I have been experimenting with implementing different zooms.
This is the case at 100% zoom
I am changing the tchart to 35% zoom by changing the View3DOptions.fontZoom. I also change plot size to 35%. It seems to basically work okay (see below)
However, the legend is too wide at the 35% zoom as compared to. I have changed the symbol width so that it scales with the zoom. but that does not help.
Are there any other properties that determine the width of the legend that I may have to change to accurately depict a zoom?
Thank you!
-Dave
Post by Pep » Mon Jan 16, 2006 9:09 am
Hi Dave,
which TeeChart Pro version are you using ? It seems to work fine using the latest TeeChart Pro v7.06.
Could you please post the code you're using to see the problem ?
David Novo
Post by David Novo » Tue Jan 17, 2006 6:40 am
I think we are using TChart 7.03 but I will have to check.
The code that we use for this is very involved. I can try to save the chart to a .tee file at the appropriate place. Would that help you?
Post by Narcís » Tue Jan 17, 2006 10:29 am
Hi David,
Then you could try this with v7.06 if possible. Regarding the .tee file, yes it would help. It would also be helpful if you could arrange a simple project reproducing we can run "as-is" reproducing this problem. You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
