Print error ColorGrid series - no data in print
Posted: Thu Jan 15, 2004 8:01 am
by 8573774
I have a colorgrid series with typically 1200 x 2500 XYZ points (a saved
binary teefile was 36M) and is used as a campbell plot. When I print the
chart the actual data is missing in the chart, but axis etc are printed ok.
No difference have been noted between different boxes (xp, nt4 & w2k)
No errormessages are noted.
Exporting as a picture does work.
Any ideas?
Posted: Thu Jan 15, 2004 3:48 pm
by Marjan
Hi.
I tried to replicate the problem you're having but to no avail. It worked just fine. Perhaps the problem is related to bitmap size or printer driver. Do you get the same results (transparent cells) for arbitrary number of points ? If you export image and then print it outside Delphi, is the image printed correctly ?
Additional information
Posted: Fri Jan 16, 2004 7:52 am
by 8573774
Ive tried different printers, and also writing to PDF but its the same result - axis are printed but data is not. When I export the chart its all OK. I also had same issue when I opened the tee-file from teechartoffce. http://www.rubore.com/temp/dmo.tee is an example teefile.
