VCL & CLX in Delphi 7 TeeAbout error
Posted: Mon Jan 12, 2004 4:32 pm
I have been using CLX not VCL since last July as prescribed in an email from steema. Recently I needed to to do a VCL program so I unchecked all the CLX packages and selected the VCL. Did my work and then tried to reverse the process. When I tryed to check the CLX packages I got the TeeAbout error.
"Cannot load package 'Tee67Clx.' It contains unit 'TeeAbout', which is also contained in package 'Tee67'.
I have tried removing the VCL packages and reinstalling the clx, recompiling and reinstalling, but the error persists.
Can you help me as this is very frustrating and I am not getting any work done.
Is there a better solution? Can TeeAbout be copied and renamed to TeeAboutClx for the Clx compile (Along the lines that Borland uses).
Bob
Bob
