How do I know the data source of a series.
SDG
Post by SDG » Fri Jan 02, 2004 4:54 am
Yesterday I have posted a question for this.
I found that the property Xvalue.Valuesource and Yvalue.Value source gives the datasource. but this property works only when the values are assigned at designtime.
How do I know the valuesource if the Dataset is assigned in the runtime?
Marjan
Re: How do I know the data source of a series.
Post by Marjan » Fri Jan 02, 2004 11:21 am
8440512 wrote:Yesterday I have posted a question for this.
It doesn't matter if it's set at design or at runtime. I guess one way to determine is series datasource is dataset is to use the following code:
  if Series1.DataSource is TDataSet then ShowMessage('Dataset descendant');
Marjan Slatinek,
