TeeChart 41 is not compatible with the latest RAD Studio
Posted: Thu Oct 17, 2024 4:59 pm
by 16597583
I installed TeeChart 41 to RAD version 29.0.53982.0329, after that I have many troubles with TeeChart DLLs.
After that I recompiled TeeChart from source codes and now one works fine.
Re: TeeChart 41 is not compatible with the latest RAD Studio
Posted: Thu Oct 17, 2024 8:55 pm
by 16498731
I had the same problem.
Posted: Fri Oct 18, 2024 7:47 am
We will do some tests asap to verify if the TeeChart binary installers don't work with the new 12.2 Patch 1.
Of course, as you've observed, having the TeeChart source code version, you can just recompile it.
Posted: Fri Oct 18, 2024 12:17 pm
by 16498731
Please, I need a solution because my version does not provide the source codes.
Is there a workaround for this situation?
Posted: Mon Oct 21, 2024 5:53 am
I've just tested the previous version, TeeChart v2021.40 is binary compatible with RAD 12.2 Patch 1.
Posted: Mon Oct 21, 2024 11:58 am
by 16498731
Thanks Yeray.
I installed this version without any problems.
