Dear Forum,
If I hover the cursor over the BottomAxis Label it resets back to some default font style .
It is I either disable Hover ... then it is okay.
Or I do a override on AfterDraw . But that does not work perfetly because the Labels are shifted a bit once , probably
missing some default parameter.
( TeeChart Pro 2022.34.220329 )
See very simple attachment .
Thank you.
TDBChart Bottom Label Font Override trough Hover Problem
- Chart.zip
- (26.7 KiB) Downloaded 193 times
Re: TDBChart Bottom Label Font Override trough Hover Problem
I can't reproduce it with the current version. Can you give it a try?
