series naming
CMG
series naming
Post by CMG » Fri Dec 19, 2003 4:52 pm
Can I change the default series name. e.g. change series1 to RtEyeVel
Marjan
Post by Marjan » Sun Dec 21, 2003 9:23 am
Hi.
Yes, but only if you add series at design time (the Name property in the Oject Inspector). At runtime you could do something like this:
var RtEyeVel: TLineSeries;
  rtEyeVel = Series1;
  rtEyeVel.AddXY(...);
On the other hand, if you simply want to change series Title property (this shows up in legend), then you can use the following code:
Series1.Title := 'RtEyeVel';
Marjan Slatinek,
