Install problems on CBuilder 10.2.3
Posted: Mon Dec 04, 2023 10:48 pm
A few days ago I replaced the included tea version with the current standard version
The Installation is a little bit buggy, iE the Install process replaced the Lib Files , but not the bpl files and so on.
I correct it manually and its worked now.
But during the start of a project, I get the Message:
" C:\Embarcadero ... Fastreport6VCL\standard\libd25\ddfsTee25.bpl cannot loaded, %1 is not a valid Win32 Application"
The Lib File ddfsTee25.bpl exists in this path.
After that all TeeChart Components are hide in CBuilder and often I get the Error Message "unknown component TChart" .
If I manually click under Menu "Component/Packages" the "TeeChart Standard 2023 Components" , the Components are visible and I can load the project and it seems to work, till the next time.
what goes wrong here ?
where can I find the job with the %1 error ?
thanks in advance
Jörg
thanks in advance
Jörg
