List of unit (uses) for all kind of series
Fab
Post by Fab » Mon Jul 10, 2023 7:49 am
I'am trying to add all kind of series available for my end-users using TChartEditor in runtime.
The unit list is here :
http://www.teechart.net/docs/teechart/vclfmx/lib/
But there is a lot of unit. Does it's exists a tip find the list of unit which are needed to uses all type of series ?
Re: List of unit (uses) for all kind of series
Post by Yeray » Tue Jul 11, 2023 1:09 pm
The VCLTee.TeeChartPro unit registers all the Pro components (editors, etc).
If you want to register the Standard series, you can call RegisterTeeStandardSeries from VCLTee.Series unit.
You can also register manually a single series or class with RegisterClass function.
Fab
Post by Fab » Wed Jul 12, 2023 7:05 am
Hello Yeray,
That I need it's not the "standard" chart. I'am looking for all the "Advanced" series unit form here :
To be available for end-user in the TchartEditor.
Do you have a tips to find it or a list somewhere ?
Does it correct if I add all the units (*.pas) which contains the function "RegisterTeeSeries" ?
Post by Yeray » Wed Jul 12, 2023 5:32 pm
You can add the TeeEditPro unit for the TChartEditor to show all the Pro options. Ie:
uses EditChar, TeeEditPro;
  EditChart(Self, Chart1);
Note the Chart Editor is made to help developers to design their charts; it's not intended or recommended for the final user because it has so many options it's quite easy to set options with little or no sense.
