Runtime creating chart with PDF export in a simple unit
johndw
Post by johndw » Fri Apr 21, 2023 10:18 am
I am using RadStudio Alexandria and would lile to runtime create a chart and export it to a PDF file. Is it possible to be done without using a form with a TChart component on by simply creating a TChart instance together with TSeries instances?
Many thanks in advance!
Kind Regards
John
Re: Runtime creating chart with PDF export in a simple unit
Post by Yeray » Mon Apr 24, 2023 3:54 pm
Hello John,
This seems to work fine for me here:
uses Chart, Series, TeePDFCanvas;
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  Chart1.View3D:=False;
  Chart1.AddSeries(TLineSeries);
  Chart1[0].FillSampleValues;
  TeeSaveToPDFFile(Chart1, 'test.pdf');
