Yeray wrote: ↑Thu Sep 15, 2022 6:25 am
Try replacing the broken strings. Ie:
612:
TeeMsg_Copyright :={$IFDEF LCL}'(C)'{$ELSE}'©'{$ENDIF}+' 1995-2022 by Steema Software';
1014:
Yes, I did it, repaired all mistaken encoding of report, Win32 is OK, Win64 is error, the message is :
TeeChart Pro
Compilation started: 2022/9/15 14:27:38
Win32 v28 (C++)
Tee928
Embarcadero Delphi for Win32 compiler version 35.0
Copyright (c) 1983,2021 Embarcadero Technologies, Inc.
96817 lines, 1.58 seconds, 993404 bytes code, 4880 bytes data.
TeeUI928
96740 lines, 1.94 seconds, 653988 bytes code, 1448 bytes data.
TeeDB928
10251 lines, 0.44 seconds, 89044 bytes code, 308 bytes data.
TeePro928
268089 lines, 4.80 seconds, 1456164 bytes code, 64296 bytes data.
TeeGL928
17284 lines, 0.38 seconds, 137612 bytes code, 3176 bytes data.
TeeImage928
30437 lines, 0.67 seconds, 341888 bytes code, 11620 bytes data.
TeeWorld928
5644 lines, 0.44 seconds, 52164 bytes code, 1080 bytes data.
TeeLanguage928
94595 lines, 1.19 seconds, 3570056 bytes code, 3712 bytes data.
TeeImport928
6423 lines, 0.70 seconds, 70656 bytes code, 244 bytes data.
DclTee928
9557 lines, 0.72 seconds, 116376 bytes code, 356 bytes data.
DclTeePro928
5892 lines, 0.81 seconds, 163916 bytes code, 472 bytes data.
DclTeeProStd928
14159 lines, 0.70 seconds, 143212 bytes code, 460 bytes data.
TeeMaker128
98029 lines, 2.12 seconds, 834024 bytes code, 12772 bytes data.
DclTeeMaker128
1135 lines, 1.41 seconds, 21552 bytes code, 224 bytes data.
FMXTee928
90555 lines, 1.45 seconds, 937136 bytes code, 4416 bytes data.
FMXTeeUI928
79828 lines, 2.02 seconds, 548076 bytes code, 1128 bytes data.
FMXTeeDB928
10269 lines, 0.59 seconds, 92708 bytes code, 308 bytes data.
FMXTeePro928
212949 lines, 4.58 seconds, 1477616 bytes code, 64708 bytes data.
FMXTeeLanguage928
94671 lines, 1.38 seconds, 3571696 bytes code, 3712 bytes data.
FMXTeeImport928
6314 lines, 0.67 seconds, 75656 bytes code, 236 bytes data.
DclFMXTee928
5285 lines, 0.67 seconds, 85512 bytes code, 288 bytes data.
DclFMXTeePro928
2349 lines, 0.89 seconds, 110532 bytes code, 308 bytes data.
16573 lines, 2.12 seconds, 185301 bytes code, 372 bytes data.
DclFMXTeeProStd928
6351 lines, 1.03 seconds, 93468 bytes code, 304 bytes data.
Compilation started: 2022/9/15 14:28:36
TeeTree2D28Tee9
51936 lines, 0.78 seconds, 629444 bytes code, 1520 bytes data.
FMXTree28
16615 lines, 0.44 seconds, 170960 bytes code, 388 bytes data.
DclTree2D28Tee9
1927 lines, 0.34 seconds, 17000 bytes code, 260 bytes data.
DclFMXTree28
836 lines, 0.45 seconds, 12728 bytes code, 208 bytes data.
TeeChart Installation
VERSION: 2022
Installing...
Win32 v28 (C++) OK. Time: 1m 2s
Win64 v28 (C++)
Tee928
Embarcadero Delphi for Win64 compiler version 35.0
96817 lines, 2.25 seconds, 1435068 bytes code, 99496 bytes data.
TeeUI928
96740 lines, 2.16 seconds, 926364 bytes code, 58044 bytes data.
TeeDB928
10251 lines, 0.52 seconds, 142236 bytes code, 8908 bytes data.
TeePro928
268089 lines, 5.86 seconds, 2126508 bytes code, 175984 bytes data.
TeeGL928
17284 lines, 0.48 seconds, 188092 bytes code, 13020 bytes data.
TeeImage928
30437 lines, 0.86 seconds, 480796 bytes code, 42760 bytes data.
TeeWorld928
5644 lines, 0.41 seconds, 82412 bytes code, 6876 bytes data.
TeeLanguage928
94595 lines, 1.75 seconds, 4730508 bytes code, 12628 bytes data.
TeeImport928
6423 lines, 0.84 seconds, 117196 bytes code, 9576 bytes data.
1106 lines, 1.62 seconds, 28884 bytes code, 4188 bytes data.
1817 lines, 0.34 seconds, 38345 bytes code, 5548 bytes data.
TeeMaker128
98029 lines, 2.31 seconds, 1156044 bytes code, 79588 bytes data.
Binding Units
4079 lines, 0.70 seconds, 113911 bytes code, 19356 bytes data.
FMXTee928
90555 lines, 2.42 seconds, 1353868 bytes code, 92024 bytes data.
FMXTeeUI928
79828 lines, 2.14 seconds, 786652 bytes code, 45832 bytes data.
FMXTeeDB928
10269 lines, 0.59 seconds, 150620 bytes code, 9044 bytes data.
FMXTeePro928
212949 lines, 5.53 seconds, 2131468 bytes code, 182228 bytes data.
FMXTeeLanguage928
94671 lines, 1.91 seconds, 4735388 bytes code, 12800 bytes data.
FMXTeeImport928
6314 lines, 0.75 seconds, 129580 bytes code, 9564 bytes data.
16573 lines, 1.66 seconds, 290350 bytes code, 39416 bytes data.
Binding Units
4082 lines, 0.52 seconds, 113200 bytes code, 19356 bytes data.
Compilation started: 2022/9/15 14:29:25
TeeTree2D28Tee9
Cannot recompile Delphi package: TeeTree2D28Tee9.dpk
TeeOfficeConstants.pas(631) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(647) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(648) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(675) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1409) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1764) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1765) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1766) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1768) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1770) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1771) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1772) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1773) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1774) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1777) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1779) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1781) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1789) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1790) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1791) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1793) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1794) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1796) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1797) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1798) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1802) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1804) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1805) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1810) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1811) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1813) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1815) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1819) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1832) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1833) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(1834) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2259) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2260) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2261) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2263) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2285) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2286) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2287) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2288) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2289) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2297) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2299) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TeeOfficeConstants.pas(2306) Error: E1057 Implicit string cast from 'AnsiString' to 'string'
TreeConst.pas(830) Fatal: F2063 Could not compile used unit 'TeeOfficeConstants.pas'
EXCEPTION:
Compilation aborted.
