I have a Delphi 11 VCL Forms application that uses TeechartVCLFMX Pro 2022.34. A page in a TPagecontrol contains a TChartLayout with 2 charts. I added a vertical cursor to one of the charts from the Tools menu and the cursor appears on the chart in in the IDE. However, when I attempt to run the application, I receive the following error message:
“Error reading DamperPVChartLayout1.Charts: Error reading TChartItem.InnerChart: class TCursorTool not found.”
Adding any other tool from the menu produces a similar error.
Class TCursorTool not found
Re: Class TCursorTool not found
We've reproduced the project as we understand you've described it and it seems to run ok. Our example project here:
https://www.steema.com/files/public/tee ... Layout.zip
Let us know if it misses some elements of your project and or/modify it and send it back to us for further tests or let us know if it fails in your IDE.
