Size of chart elements
Posted: Tue Oct 05, 2021 9:29 am
by 16591932
I'm trying to understand the vertical alignments of the various elements that make up the chart. At run time it is possible to get the size in pixels the height of the top and bottom margins, the chart title, the axes titles, the chart rectangle itself, and the legend. But I can't see how to get the height occupied by the axis labelling. Is there a property that returns this?
Re: Size of chart elements
Posted: Tue Oct 05, 2021 1:28 pm
I did an example trying to show all the heights involved in a simple chart:
uses Series;
type TCustomTeePanelAccess=class(TCustomTeePanel);
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Chart1.Color:=clWhite;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
  RecalcHeights;
procedure TForm1.RecalcHeights;
var total: Integer;
  procedure AddValue(const title: String; const AValue: Integer);
    Inc(total, AValue);
    Memo1.Lines.Add(title + ': ' + IntToStr(AValue) + ', Subtotal: ' + IntToStr(total));
  Chart1.Draw;
  Memo1.Clear;
  Memo1.Lines.Add('*** Heights ***');
  Memo1.Lines.Add('Total Chart: ' + IntToStr(Chart1.Height));
  Memo1.Lines.Add('');
  total:=0;
  AddValue('BorderSize', TCustomTeePanelAccess(Chart1).BorderSize);
  if (Chart1.MarginUnits = muPixels) then
     AddValue('Margin Top', Chart1.MarginTop)
     AddValue('Margin Top', Chart1.Height*Chart1.MarginTop div 100);
  AddValue('Title', Chart1.Title.Height);
  AddValue('Title Margin', Chart1.Title.VertMargin);
  AddValue('ChartRect', Chart1.ChartRect.Height);
  with Chart1.Axes.Bottom do
    AddValue('Bottom Axis Ticks Margin', Axis.Width+1);
    AddValue('Bottom Axis Ticks', TickLength);
    AddValue('Bottom Axis Labels', Abs(LabelsFormat.Height));
    AddValue('Margin Bottom', Chart1.MarginBottom)
    AddValue('Margin Bottom', Chart1.Height*Chart1.MarginBottom div 100);
