How to benchmark TChart recalc / redraw times?
FOCUS electronics
Post by FOCUS electronics » Fri Apr 23, 2021 10:36 am
Hello all,
I'd like to benchmark the times required for adding points to a TLineSeries and the actual time consumed during redraw. If I understand correctly, the redrawing is performed in next call to message loop.
Is there an example how to benchmark the redraw performance?
Best regards,
Focus
Re: How to benchmark TChart recalc / redraw times?
Post by Yeray » Mon Apr 26, 2021 9:13 am
You can start a TStopWatch at the Chart's OnBeforeDraw event calculate the elapsed time at OnAfterDraw event. Ie:
uses Diagnostics, TimeSpan;
var stopWatch: TStopwatch;
procedure TForm1.ChartBeforeDraw(Sender: TObject);
  label1.Caption:='Drawing...';
  stopWatch:=TStopwatch.Create;
  stopWatch.Start;
procedure TForm1.ChartAfterDraw(Sender: TObject);
var elapsed: TTimeSpan;
    seconds: Double;
  elapsed:=stopWatch.Elapsed;
  seconds:=elapsed.TotalSeconds;
  label1.Caption:='Drawing took ' + FormatFloat('#,##0.##', seconds) + ' seconds';
