Map Series of Shapefile
Fodder77
Post by Fodder77 » Mon Aug 17, 2020 6:44 am
Hi All,
I am trying to create some maps from shapefiles. So far, I have managed to draw the polygons in a shapefile with the code below.
However, I can't figure out how to load or access the attributes of the shapes from the dbf file. Can anyone help?
I also couldn't find an example of Map Series with GIS layers (at https://github.com/Steema/TeeChart-VCL-samples)?
When I try to compile the TeeChart_Maps project, I get a Unit DBTables not found error. I am using: Steema TeeChart Pro VCL FMX Source Code 2020.30
 Chart1.View3D := false;
 Chart1.Legend.Visible := false;
  series1 := TMapSeries.Create(Chart1);
  Chart1.AddSeries(series1);
  series1.Clear;
  SHPFile := 'shapes.shp';
  try
    LoadMap(Series1 , SHPFile);
  finally
  Series1.ColorEachPoint := true;
Fodder77
Re: Map Series of Shapefile
Post by Fodder77 » Thu Aug 20, 2020 8:34 am
Hi everyone,
I have made a bit of progress, I installed BDE and was able to compile the Map Layer demo including reading shapefile attributes using DBTables TTable. However, is there a preferred object to use now BDE is deprecated?
My next issue is that many of my shapefiles return the 'corrupt table index/header' error on TTable.Open despite the fact that they work fine in GIS applications. Does anyone have any ideas on this?
Is KML a better format to use than SHP with TeeChart? Can TeeChart retrieve values and names from KML files similar to SHP?
Post by Yeray » Thu Aug 27, 2020 5:56 am
I'm not an expert on the subject but migrating from BDE to FireDAC seems to be the most recommended.
I'm afraid I don't have enough information here. If you think the problem is in TeeChart, please try to arrange a simple example project we can run as-is to reproduce the problem here.
You can load KML files using TTeeKMLSource as in the example here. Have you tried it?
