Top/Bottom line in a chart
Posted: Thu Apr 09, 2020 3:53 pm
by 16587426
I have a horizontal bar series in a chart. A customer wants the axis line on the bottom of the chart to extend farther left, and one at the top that matches. See here:
I put arrows showing the lines.
Is something like this possible? (I have attached a demo--if it can be done, do you mind updating the demo).
Much appreciated.
Ed Dressel
Re: Top/Bottom line in a chart
Posted: Tue Apr 14, 2020 8:15 am
Here with a margin of 10 pixels each side:
- Project1_2020-04-14_10-14-09.png (12.82 KiB) Viewed 16980 times
Posted: Wed Apr 15, 2020 3:52 pm
by 16587426
Thank you. That works perfect for the TChart, but when I create an image of the chart with a different width, the lines are not the correct width. See the attached demo--the red lines are painted in the AfterDraw event and are not the correct width.
Posted: Mon Apr 20, 2020 2:01 pm
by 16587426
Hello?
Posted: Wed Apr 22, 2020 5:49 pm
by Marc
This is an option:
Add two new variables in the var declarations of the Form:
var
Form1: TForm1;
aWidth, chartWidth : Integer; ///<-- these
In FormCreate initialise the variables:
var
I: Integer;
lValue: Double;
aWidth:=Chart1.Width; //<-- here
chartWidth:=aWidth; //<-- and here
Series1.Clear;
In the AssignChartToGraphic method add in a set for aWidth:
lCanvasClass := TCanvas3DClass(aChart.Canvas.ClassType);
if lCanvasClass <> TTeeCanvas3D then
aChart.Canvas := TTeeCanvas3D.Create;
aWidth:=aRect.Right; //<--- here
lHoldGradientVisible := aChart.Gradient.Visible;
In the OnAfterDraw event add in the variable width size and reset the variable.
ie.
with Chart1.Canvas do begin
Pen.Color := clRed;
Pen.Width := Chart1.BottomAxis.Axis.Width;
HorizLine3D(10,aWidth-10,Chart1.ChartRect.Top,0);
HorizLine3D(10,aWidth-10,Chart1.Axes.Bottom.PosAxis+1,0);
aWidth:=chartWidth; //reset
Unit attached.
